This is a YouTube video. What does this dimension (5.50) mean? It is confusing, in my view it is not necessary.
The only thing that I can think of is this:
Either it is dimensioning the depth of a hole, and then hidden lines were turned off (which is a Drafting no-no).
OR it was dimensioning a feature that was later deleted and they forgot toe delete it.
Hi Maha,
It seems you've posted this same question twice. You might want to think about deleting the other post?
Dave.
Never, that was again a dimension problem but different question. As I do not have enough exposure. I am unable to decide correct or not.
The second post is still active Maha and it IS the same question like I mentioned.
You'll notice this one has a different thread number. Maybe you forgot to edit it or something, but at the moment it's the same The specified item was not found.
Dave.
There could be a possibility that dimensions were given using import model items and 5.5 cam along with that from the feature. But looking at this drawing, this is no required.
……………dimensions were given using import model items……….
This is a frequent problem in the YouTube video, better clarification is helpful. What is meant by “import model items”?
That should be "Insert Model Items", not import.
2016 SOLIDWORKS Help - Model Items
The 5.5 dimension is probably related to the depth of a Hole Wizard hole or other type of hole. Even hough the end result is a through hole, the underlying dimensions of the hole depth is still taken into account.
