hello guys i just wanted to design a car in solidworks by using surface design but there is problem i want to create a boundary surface between two curves, one of the curves has been used by another boundary surface feature and heres the problem solidworks tells me that the selected curve is already owned by another feature i dont know what to do i can sketch the curve again but it would be so much time consuming. if anybody knows plz help me
if the file of the car helps you in answering just tell me..
..is/was it a "composite curve, projected curve or curve thru points " ?... if so, is/was the error "selected object is already owned by a feature"?
.. that is, if you have 2015 and earlier,.. you would need to copy the curve using a 3dsketch and use convert edge....
...if it is 2016 and current it should work,.. so, I'm not sure what or why,...
