This content has been marked as final.
Show 5 replies
Re: Pattern Driven Component Pattern
J. Mather Dec 24, 2016 2:07 PM (in response to Maha Nadarasa)Can you attach your assembly here?
Maha Nadarasa Dec 24, 2016 2:24 PM (in response to J. Mather)In addition to parts, I got 47 files in the assembly folder all that are relevant, which may confuse you. I will refine the folder and attach.
Maha Nadarasa Dec 24, 2016 3:05 PM (in response to J. Mather)ZIP file is too large to attach. I am thinking what is the alternative way to attach.
Glenn Schroeder Dec 31, 2016 1:49 PM (in response to Maha Nadarasa)Maha,
When using the "Pattern Driven Component Pattern", after selecting the component (or components) to pattern, you need to select the driving feature (the blue box in the screenshot in your first post here). In other words, you need to expand the tree and select the feature that created the pattern of the six holes. Presumably they were created with a Circular Pattern or the Hole Wizard. If not, then you may not be able to use the feature.
