I have been noticing some odd behavior since upgrading from last years version to the newest version. This happens with parts as well, but it is most noticeable when working with assemblies.
Whenever I am trying to grab a part to move it around in the assembly, or to set relationships with other parts (via top down design and whatnot), the mouse cursor automatically gains the little dimension tool symbol on it, and tries to set/select a dimension within the assembly. This is getting very annoying because I am having to zoom WAAAAAAY in on the assembly to be able to select what I want to, or I have to fight over and over again to get the correct thing to happen.
Is there some setting that I have accidentally turned on that is causing this, because I'd really like to turn it off.
Someone please help!
Michael
Check your mouse double click setting OR replace your mouse.
Also check if you've Instand3d/2d set to off.
