I create a project or sub-project and use "check in from
disk" to place a non-SWorks item in the just-created project. When
I check the doc info for that item, the project name does not show
in the "where used" column. Next, I "check in from disk" to attach
another Non-SW file to the previous file. Now I can check that
doc's info and the where-used column shows the name of the project
which the previously queried file belongs to. The "where-used" does
not however show the file that the 2nd-entered file is attached to.
Am I wrong to expect that every file should show the next-higher tree level as a "where-used" listing?
