Hi all,
I'm currently trying to add two new sub-assemblies to my main assembly but when I do it seems that nearly all of the mates in the sub-assemblies that the newly inserted sub-assemblies will be mated to break down and give me 'red-errors'. The existing sub-assemblies are fine prior to the new insertions but the frustrating part is that these have a lot of 'working' parts in them and these are the mates that are breaking down as well as others.
The newly inserted sub-assemblies are NOT mated to any of the working parts of the existing sub-assemblies and they are only mated by basic flange to flange so why is this corrupting things in the way that it is and how can it be prevented?
Regards Dave.
Sometimes I will have an assembly that shows red or yellow errors on my mates when I KNOW that there are no issues.
2 things could have happened:
1) a global update just needs to happen: if this is the case, then a simple CTRL Q will solve the issue.
2) one of the mates might have "Flipped" when you added to the main assembly. See if that is the case.
and example of being "flipped" is when you create a tangent mate to the left hand side of a cylinder and the mate "flips" to the right hand side instead.
