Wait for assembly to load before executing macro feature
Question asked by Farzad Sidhva on Dec 21, 2016
Latest reply on Jan 4, 2017 by William Cruz
I am attempting to run a simple macro that gets custom property data from a top level model and passes it to a subassembly within said top assembly. I want it to run every time the model is opened so I have the macro called in a macro feature. It seems as though the macro is being executed too early and is causing crashes occasionally before the full top assembly is loaded. I have tried using a timer prior to executing but seeing as this macro will run on different systems, rebuild times could take between 5 and 30 seconds. I have also tried looping a Do while swActiveDoc is nothing and that simply causes the program to stop running (I have been coding for less than a year so I apologize if that was not even close to the right solution).Is there a way to have the program wait until the model is fully loaded before executing? Note that the macro runs fine when executed outside of the macro feature. Also note that the comments in the program are for those at my company that wouldn't know what they are doing when they see this.
Thank you for your time,
Farzad Sidhva
Option Explicit
Dim swApp               As SldWorks.SldWorks
Dim swModel_1           As SldWorks.ModelDoc2
Dim swModel_2           As SldWorks.ModelDoc2
Dim swCustProp          As CustomPropertyManager
Dim Model_1Name         As String
Dim Model_2Name         As String
Dim val                 As String
Dim instances           As String
Dim length              As String
Dim WireRatio           As String
Dim RndSpacing          As String
Dim spacing             As String
Dim WireLength          As String
Dim VarDocFileName      As String
Dim Side_Markers        As String
Dim bool_1              As Boolean
Dim bool_2              As Boolean
Dim bRet                As Boolean
Dim nErrors             As Long
Dim nWarnings           As Long
Dim swModelDocExt       As ModelDocExtension
Sub GetProperty()
    'Set pointer to the top level assembly, get the name of the assembly, and get the 2 driving custom properties
    Set swModel_1 = swApp.ActiveDoc
    Let Model_1Name = swModel_1.GetTitle
    Set swModelDocExt = swModel_1.Extension
    Set swCustProp = swModelDocExt.CustomPropertyManager("")
    bool_1 = swCustProp.Get5("NUMBER OF SIDE MARKERS", False, val, instances, True)
    bool_2 = swCustProp.Get5("TRAILER LENGTH", False, val, length, True)
        Debug.Print "TOP LEVEL FILE NAME = "; Model_1Name
        Debug.Print "INSTANCES = "; instances
        Debug.Print "LENGTH = "; length
    'An equation for the spacing based on trailer length and number of marker lights was derived from a best fit line of all marker possibilities
    'it is then rounded to the nearest 10 because the side panels are always 10" in width
    WireRatio = length / instances
    spacing = (1.4568 * WireRatio) - 16.948
    RndSpacing = 10 * Int((spacing / 10) + 0.5)
        Debug.Print "WIRE RATIO = "; WireRatio
        Debug.Print "SPACING = "; spacing
        Debug.Print "ROUNDED SPACING = "; RndSpacing
    'This section determines what file to write the custom properties, the max and min spacing for each harness size was determined by our controls analyst
        If spacing <= 15 Then
            WireLength = 24
            ElseIf spacing <= 25 Then
            WireLength = 36
            ElseIf spacing <= 50 Then
            WireLength = 60
            ElseIf spacing <= 70 Then
            WireLength = 84
            ElseIf spacing <= 90 Then
            WireLength = 108
            ElseIf spacing <= 110 Then
            WireLength = 120
            ElseIf spacing <= 120 Then
            WireLength = 132
            ElseIf spacing <= 150 Then
            WireLength = 168
            ElseIf spacing <= 210 Then
            WireLength = 228
            Else
            WireLength = 276
        Debug.Print "WIRE LENGTH = "; WireLength
    'The file names of the affected assemblies are syntaxed as such that the only thing that changes is one number
    'This section opens the required assembly, gets the name of the assembly (without the extension or path), sets the custom property, and rebuilds it
    VarDocFileName = "C:\EXAMPLE\000s\MODELS\" & WireLength & " IN SIDE MARKER SPACING.SLDASM"
    Set swModel_2 = swApp.OpenDoc6(VarDocFileName, swDocASSEMBLY, 1, "Default", nErrors, nWarnings)
    Let Model_2Name = swModel_2.GetTitle
        Debug.Print "MARKER ASSEMBLY FILE NAME = "; Model_2Name
    Set swCustProp = swModel_2.Extension.CustomPropertyManager("")
    swCustProp.Set2 "SIDE_MARKERS", instances
    bRet = swModel_2.ForceRebuild3(False)
    'The active document is then switched to the original and is rebuilt. Then the sub-assembly document is closed
    Set swModel_1 = swApp.ActivateDoc2(Model_1Name, True, nErrors)
    bRet = swModel_1.ForceRebuild3(False)
