Cutlist does not update
Question asked by Saeed Mojarad on Dec 19, 2016
Hi everyone,
I am trying to make a macro that copies the cutlist properties into configuration properties. I could do it for a part with one configuration using the following macro. The problem is for configurations that are not active it returns values like "LENGTH@@@Cut-List-Item4@Weldment.SLDPRT" instead of the actual length. I am not sure what I am missing here.
Regards,
Saeed
Option Explicit
Dim swApp           As SldWorks.SldWorks
Dim swModel         As SldWorks.ModelDoc2
    Dim swCustPropMgr   As SldWorks.CustomPropertyManager
    Dim strValue        As String
    Dim ThisFeat        As SldWorks.Feature
    Dim ThisSubFeat     As SldWorks.Feature
    Dim CutFolder       As SldWorks.BodyFolder
    Set swModel = swApp.ActiveDoc
    Set ThisFeat = swModel.FirstFeature
    Do While Not ThisFeat Is Nothing
        Set ThisSubFeat = ThisFeat.GetFirstSubFeature
        Do While Not ThisSubFeat Is Nothing
            If ThisSubFeat.GetTypeName = "CutListFolder" Then
                Set CutFolder = ThisSubFeat.GetSpecificFeature2
            If Not CutFolder Is Nothing Then
                If CutFolder.GetBodyCount > 0 Then
                    Call LinkToCustomProperties(ThisSubFeat)
            Set ThisSubFeat = ThisSubFeat.GetNextSubFeature
        Loop
        Set ThisFeat = ThisFeat.GetNextFeature
    Loop
Sub LinkToCustomProperties(CutListFeature As SldWorks.Feature)
    Dim cutlistPropMgr          As SldWorks.CustomPropertyManager
    Dim propNames               As Variant
    Dim vName                   As Variant
    Dim propName                As String
    Dim Value                   As String
    Dim resolvedValue           As String
    Dim config                  As SldWorks.Configuration
    Dim customPropMgr           As SldWorks.CustomPropertyManager
    Dim lRetVal                 As Long
    Dim i                       As Integer
    Dim sConfigName             As String
    Dim vConfigName             As Variant
    Dim SolidBodyFeature        As SldWorks.Feature
    Dim SolidBodyBodyFolder     As BodyFolder
    Dim MyFeatureManager        As Object
    Set cutlistPropMgr = CutListFeature.CustomPropertyManager
    vConfigName = swModel.GetConfigurationNames
'Go through the configurations and add all the cutlist properties for all the configurations to configuration properties
    For i = 0 To UBound(vConfigName)
        sConfigName = vConfigName(i)
        swModel.ShowConfiguration2 (sConfigName)
        Set MyFeatureManager = swModel.FeatureManager
        'Update Feature manager
        MyFeatureManager.EnableFeatureTree = True
        MyFeatureManager.UpdateFeatureTree
        'Force rebuild the part
        swModel.ForceRebuild3 True
        Set SolidBodyFeature = swModel.FirstFeature
        Do While Not SolidBodyFeature Is Nothing
            If SolidBodyFeature.GetTypeName2 = "SolidBodyFolder" Then
                Set SolidBodyBodyFolder = SolidBodyFeature.GetSpecificFeature2
                If SolidBodyBodyFolder.UpdateCutList Then
                    Exit Do
            Set SolidBodyFeature = SolidBodyFeature.GetNextFeature
        Loop
        Set config = swModel.GetConfigurationByName(sConfigName)
        Debug.Print sConfigName
        Set customPropMgr = config.CustomPropertyManager
        If Not cutlistPropMgr Is Nothing Then
            propNames = cutlistPropMgr.GetNames
            If Not IsEmpty(propNames) Then
                Debug.Print CutListFeature.Name, CutListFeature.GetTypeName
                For Each vName In propNames
                    propName = vName
                    Call cutlistPropMgr.Get2(propName, Value, resolvedValue)
                    Debug.Print "", "", propName, Value, resolvedValue
                    lRetVal = customPropMgr.Add3(CutListFeature.Name & "_" & propName, swCustomInfoType_e.swCustomInfoText, resolvedValue, swCustomPropertyAddOption_e.swCustomPropertyDeleteAndAdd)
                Next vName
    Next
