Hi All, I have an issue with a sheetmetal part. how do I stop the sketched bend line going through to the tab?
I Just want the bend to go through the main plate, not the tab
Hi Shayne,
yes, Bernie is right. Sketched bend always assumes that the bend will go across the whole sheet metal body even though the sketched line is shorter. To my knowledge the only workaround is to usually create a narrow bend relief manually in order to separate the bend area (basically create a small cut in the flat that will separate the bend after the part gets bent).
Kind regards
Frank
SOLIDWORKS Product Definition Team
Shayne,
It's hard to identify the problem by looking at the picture.
Can you post the problem part here?
