I wish to know is there any authentic Windows 10 repair software to download.
To download YouTube videos I had a software installed which placed a button under the video, just a click of that button I could download the video I wanted.
That software is no longer working, I tried to reinstall again which is producing an error message. In my view it is a problem with windows registry. I hope Windows 10 repair software can fix it.
I found this site that explains the legal use - though it is still confusing.
[Solved] Is It Legal or Illegal to Download YouTube Videos?
Mostly depends on what you will do with it.
Maha,.. it's a Chrome add-on?... maybe uninstall/reinstall? Over the years, I've seen some very odd problems using Chrome.. uninstall/reinstall Chrome has solved most of my problems.
I uninstall and reinstall Chrome but it didn’t solve the problem. I see add before starting a YouTube video do you mean that add?
I also have seen some very odd problems using Chrome. Many times I think to switch over to Internet Explorer but as I am familiar with Google Chrome I have a hesitation to so.
I purchased Tweaking.com - Windows Repair Proa. What is meant by Installer or Portable? one is .exe file other one is .zip file.
..yes, initially, uninstall "savefromnet" and reinstall... if that does not work.. uninstall/reinstall chrome... (but you did that already)...so, it may be a permissions issue or your windows user account (registry) is corrupt?? Do you have Admin permissions?
Similar to reparing Solidworks,.. manually removing (or rename old).. is another way to clean up Chrome... (if you know how.. be careful)
Also,.. have you tried logging in as a different user and see if this works? If not, create a new user account and see if "savefromnet" works or not?.... "If" it works... it may point towards your original account as corrupt (not uncommon).
Tweaking.. yes, it has both options,.. portable (thumbdrive) and the *.msi installer. I use the *.msi... you should have Admin rights... and if you do this.. step through each option and do the reg and restore backups... (note, you should Admin rights when running this) (be aware,.. this takes a while to run,.. be patient)
Good luck man!
What's wrong with your windows 10?
try this
Here is the URL:
http://www.nirsoft.net/
