Is there a good way to simulate an endothermic reaction? I know SW Flow Simulation doesn't compute chemical reactions, but when they're endothermic (or exothermic) there should be a way to remove (or add) heat caused by the reaction itself. Maybe adding a separate part to the assembly that extracts or produces the same amount of Btu/hr???
An endothermic reaction is a reaction that absorbs heat in order to take place. My chemistry book states it specifically as "a process in which heat flows from the surroundings into the reaction system." An easy way to identify this is through the sign of delta H for the equation. If it is positive, the reaction is endothermic. EX: When you mix ammonium nitrate and water (the stuff inside of "cold packs"), an endothermic reaction takes place. The reaction absorbs heat making the surrounding area feel colder (thus making "cold packs" function the way they do). Check this weblink for getting complete analysis.
