Add Corner Trim to a sheet metal part
Question asked by Casey Brown on Nov 19, 2008
Latest reply on Nov 19, 2008 by Joel Bickel
Hi, Guys!
I'm new to SolidWorks and I'm having some trouble in the corner reliefs in a Sheet Metal part. I need to add a square cut out in the bent up corners. And I don't even have the option of adding this style of corner trim. I have the normal auto-relief options (rectangle, obround & tear) and I am using the tear option for welding that is going to take place. I have tried the Help option through SW, and I have surpressed the Flat-Pattern option but im not even get the option under 'Corner Options' all I get is 'corner Treatment;. I'm just not sure where to go from here since it's not there as an option. I have also tried the Insert, Sheet Metal, Add Corner Trim, but that is just a faded picture where I'm unable to even select it. I would greatly appreciate and all help, advice any ideas that you guys might have. Thanks!!!
