makes a difference, 3D can export igs files you get a dumb solid.
2D dwg's or dxf then you will have to use the 2D to 3D in SW to get
it done.
from the help file in SW:
2D to 3D Conversion Overview
You can convert 2D sketches into 3D models.
The 2D sketch can be an imported drawing, or it can be a sketch
constructed in SolidWorks. In either case, it must be a single
sketch in a part document.
NOTE: Even though the sketch can be an imported drawing, it must be
imported into a sketch in a part document. You can copy and paste
the drawing from a drawing document, or you can import the drawing
directly into a 2D sketch in a part document.
The conversion procedure is generally as follows:
In a part document, import a drawing into a sketch or construct a
new sketch.
Edit the sketch.
Extract sketches for views from the Front, Top, and so on. The
sketches fold up into the appropriate orientation.
Align the sketches.
Extrude the base feature.
Cut or extrude other features.
The tools for the conversion process are on the 2D to 3D
Toolbar.
2D dwg's or dxf then you will have to use the 2D to 3D in SW to get it done.
The 2D sketch can be an imported drawing, or it can be a sketch constructed in SolidWorks. In either case, it must be a single sketch in a part document.
NOTE: Even though the sketch can be an imported drawing, it must be imported into a sketch in a part document. You can copy and paste the drawing from a drawing document, or you can import the drawing directly into a 2D sketch in a part document.
In a part document, import a drawing into a sketch or construct a new sketch.
Edit the sketch.
Extract sketches for views from the Front, Top, and so on. The sketches fold up into the appropriate orientation.
Align the sketches.
The tools for the conversion process are on the 2D to 3D Toolbar.
