My shortcut to the PDMWorks Vault Admin is no good since
installing SolidWorks 2009. Any ideas? I updated the Vault software
on our server and when I open Solidworks it logs into PDMWorks, but
I can't access the Vault Admin to add new projects, change
settings, etc...
Look for this file pdmwVaultAdmin.exe . If for some reason it's not to be found, try reinstalling SW Explorer with PDMWorks Admin tool included in install.
I concur with the above from Troy but you should have saved your PDM settings prior to install. Your pdmrc folder in C:\VaultData is the folder with all that info.
Good luck,
