I make a lot of two-profile lofts to simulate bent wire routing in wire harnesses.
After picking the two profiles, I need to have the following settings as default:
- Start/End Constraints
-Start constraint:
-Normal To Profile
-End constraint:
-Normal To Profile
- Options
- Un-check Merge result
If I could have these default settings active every time I start Solidworks it would save me a ton of time!
I doubt if there's any way to change the default settings, but I can't help but ask: Why are you using Lofts instead of Sweeps to create wire? Isn't it the same size and shape at each end?
