macro gets stuck, can't find out on which part
Question asked by K. V. on Dec 15, 2016
Latest reply on Dec 21, 2016 by K. V.
I can't figure out why this macro is stuck, anyone that can help me? It is for Deleting suppressed parts/assembly's
    Dim swApp                 As SldWorks.SldWorks
    Dim swModel               As SldWorks.ModelDoc2
    Dim swAssy                As SldWorks.AssemblyDoc
    Dim swConf                As SldWorks.Configuration
    Dim swRootComp            As SldWorks.Component2
    Set swModel = swApp.ActiveDoc
    Set swConf = swModel.GetActiveConfiguration
    Set swRootComp = swConf.GetRootComponent
    TraverseComponent swRootComp, swModel, 0
Sub TraverseComponent(swComp As SldWorks.Component2, RootModel As SldWorks.ModelDoc2, ByVal iLev As Integer)
    Dim vChildComp            As Variant
    Dim swChildComp           As SldWorks.Component2
    Dim swCompConfig          As SldWorks.Configuration
    Dim i                     As Long
    Dim iRueck                As Double
    Dim oModel, oModComp      As ModelDoc2
    Dim iSel                  As Object
    Dim b                     As Boolean
    Dim o                     As Object
    Dim iLevel                As Integer
    iLevel = iLev + 1   ' This variable is meant to show the sub-level the macro currently works in
    Debug.Print iLevel & "|" & swComp.Name
    vChildComp = swComp.GetChildren
    For i = 0 To UBound(vChildComp)
        Set swChildComp = vChildComp(i)
        If swChildComp.IsSuppressed Then   ' Identified a suppressed part - Aim is to kill this one, no matter if it is assembly or part
            Debug.Print "Suppr.: " & swChildComp.Name
            swComp.Select4 False, Nothing, False
            RootModel.EditAssembly
            b = swChildComp.Select4(False, iSel, False)
            b = RootModel.Extension.DeleteSelection2(1)
            iCountDelete = iCountDelete + 1
            RootModel.ClearSelection2 (True)
            If b = False Then i = swChildComp.SetSuppression2(0)
        TraverseComponent swChildComp, RootModel, iLevel
    Next i
