So I have a small abs case I need to make a positioning jig
for. The jig needs to be a reasonably good fit into one aperture of
the case, with an overhang that has to match the surface profile of
the case with a minimal offset.
The attached picture: I've highlighted the two faces I need to use as the cutting surfaces. While I have no problem offsetting them either as zero or say 0.1mm, I cannot seem to use them if I then apply a cut with surface on the underside of the overhang you see in the picture (exploded 12.5mm upwards for clarity).
I've created the jig in context within the assembly... Any pointers gratefully received.
