7 Replies Latest reply on Nov 13, 2008 2:12 PM by Luke Malpass
    Layer Macro
    Tony Hayes
      Good Morning All,
      I found this sample in the API help. I would like to use this macro but I cannot get it to work. Could someone please lead me in the right direction for it to work.
      Option Explicit
      Public Enum swLineStyles_e
      swLineCONTINUOUS = 0
      swLineHIDDEN = 1
      swLinePHANTOM = 2
      swLineCHAIN = 3
      swLineCENTER = 4
      swLineSTITCH = 5
      swLineCHAINTHICK = 6
      End Enum
      Public Enum swLineWeights_e
      swLW_NONE = -1
      swLW_THIN = 0
      swLW_NORMAL = 1
      swLW_THICK = 2
      swLW_THICK2 = 3
      swLW_THICK3 = 4
      swLW_THICK4 = 5
      swLW_THICK5 = 6
      swLW_THICK6 = 7
      swLW_NUMBER = 8
      swLW_LAYER = 9
      End Enum
      Private Sub ChangeComponentLayer _
      ( _
      swApp As SldWorks.SldWorks, _
      swDraw As SldWorks.DrawingDoc, _
      swDrawComp As SldWorks.DrawingComponent, _
      sLayerName As String _
      Dim bRet As Boolean
      ' Form a legal layer name by replacing backslash (/) and at sign (@) symbols
      ' with underscores
      sLayerName = Replace(sLayerName, "/", "_")
      sLayerName = Replace(sLayerName, "@", "_")
      bRet = swDraw.CreateLayer( _
      sLayerName, _
      "layer for " & sLayerName, _
      0, swLineCONTINUOUS, swLW_NORMAL, True): Debug.Assert bRet
      swDrawComp.Layer = sLayerName
      Sub ProcessDrawingComponent _
      ( _
      sPadStr As String _
      Dim vDrawCompChildArr As Variant
      Dim vDrawCompChild As Variant
      Dim swDrawCompChild As SldWorks.DrawingComponent
      Debug.Print sPadStr & swDrawComp.Name
      ChangeComponentLayer swApp, swDraw, swDrawComp, swDrawComp.Name
      vDrawCompChildArr = swDrawComp.GetChildren
      If Not IsEmpty(vDrawCompChildArr) Then
      For Each vDrawCompChild In vDrawCompChildArr
      Set swDrawCompChild = vDrawCompChild
      ProcessDrawingComponent swApp, swDraw, swDrawCompChild, sPadStr + " "
      Next
      Dim swView As SldWorks.View
      Dim swDrawComp As SldWorks.DrawingComponent
      Dim bRet As Boolean
      Set swModel = swApp.ActiveDoc
      Set swDraw = swModel
      Set swView = swSelMgr.GetSelectedObject5(1)
      Set swDrawComp = swView.RootDrawingComponent
      Debug.Print "File = " & swModel.GetPathName
      Debug.Print " " & swView.Name & " [" & swView.Type & "]"
      ProcessDrawingComponent swApp, swDraw, swDrawComp, " "
        • Layer Macro
          Luke Malpass
          What exactly is the problem you are having?
            • Layer Macro
              Tony Hayes
              Thanks for the quick response.
              First I know very little about API but I am tring to learn it. I plan on buying your book in the next couple of weeks. How much is your book in US dollers from your website?
              I was thinking that I could copy that code from the help into the API, is that correct? After I copied it then I try to run I get this error.
                • Layer Macro
                  If you select the VIEW on your Drawing this program Work's.
                  Marc
                  swLineHIDDEN = 1
                  swLinePHANTOM = 2
                  swLineCHAIN = 3
                  swLineCENTER = 4
                  swLineSTITCH = 5
                  End Enum
                  swLW_NONE = -1
                  swLW_THIN = 0
                  swLW_NORMAL = 1
                  swLW_THICK = 2
                  swLW_THICK2 = 3
                  swLW_THICK3 = 4
                  swLW_THICK4 = 5
                  swLW_THICK5 = 6
                  swLW_THICK6 = 7
                  swLW_NUMBER = 8
                  swLW_LAYER = 9
                  End Enum
                  Private Sub ChangeComponentLayer(swApp As SldWorks.SldWorks, swDraw As SldWorks.DrawingDoc, swDrawComp As SldWorks.DrawingComponent, sLayerName As String)
                  Dim bRet As Boolean
                  bRet = swDraw.CreateLayer(sLayerName, "layer for " & sLayerName, 0, swLineCONTINUOUS, swLW_NORMAL, True): Debug.Assert bRet
                  Sub ProcessDrawingComponent(swApp As SldWorks.SldWorks, swDraw As SldWorks.DrawingDoc, swDrawComp As SldWorks.DrawingComponent, sPadStr As String)
                  Next
                  Dim bRet As Boolean
