Eric Larson
Upper and Lower Case?
Discussion created by Eric Larson on Nov 12, 2008
Latest reply on Oct 2, 2009 by Luke Malpass
Has any one else noticed that in the new 2009 software when you try to save any part or assembly, if the caps lock is on when you enter the save window the text you enter will be in lower case, and if you turn the caps lock off the text will be in upper case? But if you enter the save window with the caps lock off in the first place then it works correctly. I know this is not really a big deal, but it is very annoying. I just wanted to know if this is happening to others or if it is just me.
