I talked to my VAR the other day briefly and they made a
comment about virtual parts. So, I've been looking into them a bit
more. Sadly documentation is poor and I'm not finding much. :frown;
Q. If I create a virtual part that has custom properties in it. Then I later create a model of that part. Is it possible to replace the new part with the virtual one and take the properties of the virtual part? Is this not the intention of a virtual file?
Thanks in advance.
Thanks in advance.
you would start with the virtual part in your assembly, and when you wanted to make it an official part, you would right click on the part in the tree and save it as an external file - probably to your vault. the part stays the same, it is just saved differently.
