Chris Young
STL options Don't Work in 2009
Discussion created by Chris Young on Nov 10, 2008
Latest reply on Nov 26, 2008 by András Szász
I have installed solidworks 2009 on two machines, both the 32 bit and 64 bit versions. The issue is when I go to export an stl file, if I go to options I can not change any thing because the OK button does not work. My only option to close the menu is to use the Cancle button. This happens in both the 32 bit and 64 bit versions. This is a big issue because we have 2 other users that are still on 2008 and will have to remain there until the bug gets fixed.
OK, Update. It does not work if you change directories. If you don't access the directories it works. At least I can save stl files, just a pain not being able to store them in a dif directory.
