In 2009 when I sketch a line, after the single line is
complete, so is the sketch line command. In 2008 I was able to
sketch multiple lines from a single line command. How can I fix
this problem?
Do you see the same thing happening with circles? If you do, you
may have 'Single command per pick' active. It's in
options->general the second box down.
Do you see the same thing happening with circles? If you do, you may have 'Single command per pick' active. It's in options->general the second box down.
Andy.
