I want to place this 9 slots on the face1 and face2 only, not on the face3. I used Circular Pattern tool but it is not responding as required. How to fix this problem? Part file is attached.
Maha,
I didn't look at your model, but you can select "Instances to Skip" and select that instance
Hope this works
As Tony said, the body isn't square. You could place the slots on Face 2 by mirroring using the Front Plane, but I haven't figured out a good way to get the slots onto Face 1. They might need to be a different length anyway since that side is shorter.
If the space between the center cut/circle is the same from the edge of surface 0, 1, & 2 - then you could use the temporary axis of that cylinder as you centerline and make a Equal Circular pattern of (4) four spaces, then you would need to "Skip" the forth instance, that will work only "if" that space from the edges are the same.
Otherwise you could insert a derived sketch etc...
Sorry, I thought that can review it from feature tree.
Instead of cut revolve I used cut extrude. I've made one sketch for all 3 sides.
After that just linear pattern.
Yep, draw the geometry you want on the top surface, offset the cut feature, then linear pattern. That's the easiest to do, and the easiest to update if the main body changes.
Your main body is not square, so a circular pattern will not work, you could mirror to one side.
