5 Replies Latest reply on Nov 10, 2008 1:19 PM by Jeff Hamilton
    Problem adding multiple sheets (Have to select sheet format)
      I am having a problem when adding multiple sheets to a drawing. When I do so, SW responds with the message "The sheet format could not be located". I then have to select it from the sheet format / properties box.
      I want to automatically create multiple sheets to exactly match the first sheet. If possible, I would also like to have revision tables inserted as per my current templates.
      It seems SW uses the template file to create the drawing and first sheet and thereafter it uses the sheet format file.
      From what I can remember it used to work the way I want it to so I'm not sure what I have done to cause this problem.
      I have looked at the system options (File locations and sheet formats) this all seems to be ok.
