We are a small company currently with just one seat. We are
cgoing to add another designer and get a second seat of solidworks.
I do alot of work form home is there away to access the vault
remotely? with workgroups or do i have to upgrade to
enterprise?
The problem is bandwidth. each file you check out must be downloaded to your machines local working directory. all communcations for vault status must also travel back and forth. Simple five second refresh of vault veiw or document info request took over five to ten minutes using remote connection. In summary, unless you can establish a remote connection with speed equivalent to at least 100mb network, then I find it almost useless to attempt remote connections for using PDM workgroup. Enterprise can do this better because it uses SQL server and replication of data.
