With Task Manager open, I noticed my SW memory use drop to 5k and then slowly build back up to 75k. My memory use (or PF below CPU use) in TM doesn't drop one bit. In some cases it actually goes up from 1.1GB to 1.20GB. During this 'freeze' time my virus detection (rtvscan.exe) ramps up double the size (this may be typical) until whatever is happening in the background stops.
Now this is a random problem and I haven't found what triggers the sequence of events. I have had my fair share of anomalies but this one has me and the IT guy baffled. We've tried turning things on, off, changing the memory allocation size, removing software, add-ins, even went as far as reloading SW.
Just wanted to throw out the problem to see if anyone else came across the same thing or if they would share some insight of things I could try.
Specs: IBM IntelliStation M Pro, XP Pro x64 SP2, Intel 2.4GB Duo Core , 2GB Ram, 150GB hard drive with ample room (41GB), NVidia 1500 with latest drivers, SW2008 SP5.0.
I am not sure what happened or how I got there but I suspect some of the tweaks I made to the vid settings with the new driver corrupted it...maybe not.
Thanks to all and check your vid drivers if your having issues.
Cheers
