Bennie Buys
Defining faces of surfaces as shells in 2009?
Discussion created by Bennie Buys on Oct 29, 2008
Latest reply on Nov 28, 2008 by Bill McEachern
In 2008 it was possible to select the split faces of surfaces and define them separateley as shells although it was only 1 surface body. How do we do it it 2009 as you can only define different surface bodies as shells.
For example we had a duct going a complex route so we used a 3D sketch and used the sweep surface command. After that different faces was generated on this sweep body by splitting the body with the curve/split line function. These different faces could previously selected and defined as different shells.
Is it still possible in 2009?
