I asked around regarding the eDrawings issue. There is an
option to save the eDrawing for all configs. I wouldn't have
expected this to include all configs for parts in the assembly but
if it does that would explain it. Can you check the file size with
this option set to the current active config only.
Development Manager - Routed systems.
Yes, adding large numbers of configurations to the library models will cause some performance degradation but I wouldn't expect it to to be as bad as you suggest. I am very surprised that it also affects the eDrawing.
I would be happy to investigate this if you could send me some data though I understand it may be inconvenient for you to do so.
Let me know if you are happy to send the data and I'll mail you the address, It'll be too large to send by email.
Cheers
on 2005 24 22:47 Merry wrote:
> We do a number of quite large piping installations and I have noticed that it
> really bogs down the computer. I was wondering if it may be because of the
> large number of configurations that I have in most of my library parts (e.g. the
> RFWN flange has over 900 configurations).
> I noticed this on a relatively small assembly when I made a model of an 'all
> thread bar'and after adding all of the diferent thread sizes and a heap of
> lengths for each size (I went up in 5mm increments) this ended up with over 2000
> configurations. I used 4 of these parts in the assembly and it bogged right
> down. Even creating an eAssembly ended being a 12MB monster that needed 1.3 GB
> of RAM to open.
> Has anybody else come to this conclusion?
