I have a Data Card with a variable Document Number, which I
want to map to a SW custom property Document Number. Within SW
Custom proprties window, I want for this property's "Value / Text
Expression" to take its value from the file's filename (with the
filename having been generated via the Template feature, using
serial numbers).
I assume that the syntax to accopmlish this would be something like, "SW-Mass@SW Part Template.SLDPRT".
Of course the vaule I want would exclude the .sldprt exention. Any ideas?
And wouldn't it be great if info like this was collected and centrally presented?
$PRP:"SW-File Name"
This if you have a data card for a file with a filename that you want filename-minus-suffix entered into a datacard field, just input the above syntax, and you will get it!
