Every time I open eDrawing application it display a warning
message "No certified OpenGL library has been found. Check your
system installation." I reinstalled the display drivers but it did
not resolve my problem.
If anyone has an idea how to resolve this please help me!
Question: What causes the following eDrawings® Professional error at start-up: "No certified OpenGL library has been found"?
Answer: According to the Autodesk® website, http://images.autodesk.com/adsk/files/readme6.htm :
On systems that have DWF Writer for 3D and eDrawings installed, opening eDrawings the first time triggers a Warning prompt: "No certified OpenGL library has been found. Check your system installation." Select OK to continue working in eDrawings.
Unfortunately, this is not eDrawings-originated and is therefore Autodesk's responsibility. Removing the DWF Writer should stop the message. If not, the graphics drivers/eDrawings may need to be reinstalled.
