I just want to make sure I'm not crazy, so I was hoping
someone could confirm this behavior, and that it is awkward.
1.) Set all planes to visible.
2.) Create a sketch on the Front plane. Insert a Sketch Picture.
3.) Create a sketch on the Top Plane.
Now, as I was sketching on the top plane, I wanted to make some points that were "visually coincident" with lines in the sketch picture on the front plane. I drew some splines, and I was dragging around the end points. Upon one drag, I missed grabbing the end of the spline, and instead grabbed the "sketch picture". I then apparently drug it onto the top plane.
My gripes with this:
1. I don't like the idea of being able to modify something in a different sketch. It didn't duplicate the sketch picture, it moved it.
2. Now that it is tied to my new sketch, and my new sketch is below my old sketch in the feature manager tree, I cannot "roll back" and copy it into the original sketch again.
3. The undo button did not return it to its original location. <-That one really hurts
Luckly I had saved a couple steps previous, so I could just reload that. Otherwise I would have to reimport the sketch picture, and try to get everything to line up again.
So, does anyone have a solution that works better? Can anyone confirm that this is an issue?
I find that I do this most often when trying to drag to hilight an area to delete mutiple lines, from the sketch that i am working on when zoomed in to the specific area that I am working on. It would be nice if the picture was visiable and would not move. Why it moves I do not know.
then start the new sketch and do the sketches you want, you wont have to worry about moving the pic. think of the sketch you are working on as a piece of tracing paper.
then all you have to do is hide the first sketch or stick it in its own folder and name it don't touch/delete design picture.
