In company we use 2 version of solidworks on 2different
Computer.( in network)
- first: SW 2008 SP2.1
-Second : SW2008 SP3.1.
The problem with toolbox is:
When I open an assembly with the second Computer (SP3.1), the size of toolbox component is biggest than origine.
On first computer (SP2.1), there is no problem, the component have good size.
I search on forum , and try to modify "Tools->Options->Hole Wizard/Toolbox" and the entry is correct
I search after the toolbox.ini --> I have not this file on the SP3.1
Try to copy/paste (with the SP2.1 file)with the good entry but don't work
I try to found with the HKEY but i don't find what and how modify
Help me please
Tbe
Help me please
Tbe
I'm assuming that you plan to share the toolbox with all users. The toolbox location would then need located on a network drive that all users have access to. Typically the location is in a folder named "Solidworks Data". So, create a folder with this name on a drive that all users can get to and then configure each computer to look in this location for the toolbox. Go to Tools > Options > Hole Wizard/Toolbox to define this.
Why are you running two different service packs? Upgrading is not difficult especially when it's done on computers running the same version.
