PDMWE Configurations not updating?
Question asked by Christina Seay on Oct 22, 2008
Latest reply on Oct 24, 2008 by Christina Seay
Has anyone else had a problem with info on the PDMWE data cards not updating across the configurations?
I have the variables set up to update all configurations, but apparently it only actually updates them when you make a change to that field on one of the cards. Which is fine, unless it's read only fields like the document name or date that the user can't edit to force the update.
If anyone else is having this problem, has anyone figured out a work around for it? Or possibly an API solution to have a button on the card to click to update all configurations, or update all configurations on a workflow transition or something?
And another related issue... I've got the document name on my data card that is populated from a folder card variable. When I take a file previously saved in the vault and save as or copy to another folder in the vault than what it was originally created in, the field on the card that's populated from the folder card variable doesn't update to the new folder.
Anyone have any thoughts, suggestions, or workarounds to these?
