We are using PDMWorks with life cycle enabled and revision
set:
Preliminary 01,02,03, etc
Released -,A,B, etc.
We have this working. The problem is check in going to rev - to rev A. We using the following steps:
The drawing is checked as a working copy.
The the drawing is revision and checkin. The the starus is changed from working to Released. This adds the rev note and new revision
Part of our drawing procedure is to add rev marks in the changed locations. The only way we know how to this is change the drawing to working, add the rev mark, and check it back in as the original rev. This is time consuming and prone to errors.
Is there a method to add the rev marks and approved during the initial rev check in.
