In past versions (~2005) I remember "driven" to be a check
box in the right click context menu of a dimension. In 2008 SP4.0
it is no longer there, and toggling requires many extra clicks and
mouse moves: left click dimension, move to property manager, click
other, move to driven check box, click. Is there a way to either
quickly toggle driving/driven status?
Or, is there a way to do accomplish my task faster with new features? I have a 3D sketch with lots of constrained and equation driven geometry. I typically 'unlock' a few degrees of freedom by changing various dimensions to 'driven', then drag the geometry to approximately where I want it. Then I switch back to driven so the equations update (without exiting the sketch and rebuilding) and to fine tune the final dimension number (make it an integer).
"Override Dims on Drag/Move" option did not help as too many degrees of freedom were movable at once.
