Does anyone have problems with the apperance in photoworks
2009?
I have an assembly with several parts and I attached apparance to parts in the assembly from the assembly level not from part level.
The problem I have is that some times the apparance of the assembly is present in a render and sometimes the apperance of the part.
I also can't delete the apperance of an assmbly itself.
This disturbs the apperance in a higher level assembly.
Everthing is set correct in the subassembly's (apperance,etc)
I set the scene. lighting etc in the top level assem.
Everything fine
I close and open the top level assm again.
SW has put apperance on the subassm, mostly default plastic.
I have to open the subassem. and then go back to top level assem.
Then the apperance is gone.
Why is SW putting apperance on the subassem?
I think there is a problem with the layer structure in SW for apperance.
(the range from assem, face, feature, body, part,)
I also can't delete the apperance in higher level.
When there is an apperance in the assem and on the part, I can't delete the apperance of the assem.
