I need some input regarding sharing assemblies.
We are working on assemblies between the three sites (main server and 2 replicating servers)
SW2008 sp3.1 PDMWE
There are several people working on different sections of the machine.
The file size of the assembly is about 50m. When a user needs to load an assembly to work on he will suppress/hide parts that does not pertain to what he is working on.
Then when the other user loads the assembly he has to go in and un-suppress/show the components.
I did read swgeek's blog about quick view /selective open and the extra select options, this helps a lot.
But, is there a preferred method on sharing assemblies?
If user A needs to work on sub-Assy "A" but needs to load sub-Assy 'B"
and user C has sub-assy "B" loaded to make changes to.
What does a users need to load, check out, should they hide/suppress components.
Do you have to check in files to have them correctly replicated?
Any input would be greatly appreciated.
Frank
SW2008 sp3.1 PDMWE
Frank
If a file is checked out, the version in the vault is replicated. You need to remember that the version being worked on [the checked out version] is not only not replicated; it is not seen by others at the local location either.
