1 Reply Latest reply on Oct 16, 2008 8:49 PM by Wayne Tiffany
    Local file clean-up
    Erik Balle
      I am having trouble with the User setting under the Explorer tab settings-> Local File Clean-Up: Automatically delete local read-only files that are not part of the vault (I have it checked) and it works fine on my system but when I checked the box on another user his local files that are not part of the vault are still there. We both have the view all files checked in the Explorer settings. Has anyone had this problem?
        • Local file clean-up
          Wayne Tiffany
          But are his files read-only? Basically that setting cleans up the orphans for you. But it's a bit dangerous in that if you really want to make sure you don't change a file and make it read-only, and it's sitting in a PDMWE folder and not in the vault, then it will disappear. I gave up and joined the crowd with that setting on - I just make sure that I add the stuff to the vault and don't manually make it read-only.
          WT
