Hi there, I have used 3D to scan module to convert the STL file to the model has many closed surfaces without holes, but how can i make these surfaces to be a solid for further modelling. Thanks a lot!!!! The attachment is the file.
Hi Thomas
The femur is a solid. You should be able to do any operation to it that can be performed on a solid.
Specifically, what do you need to do with it?
