How to retrieve 4 corner root point of the plane or surface?
Question asked by Eng Woei Lim on Dec 14, 2016
I using this code to retrieve the root point of a surface. I need the XYZ coordinates to do some translation at later stage. However, the problem I am facing is, on different part file (but same shape and geometry,just drawn by different user), the root point is reported on different corner, sometime bottom left corner, sometime top left corner, anyway to fix it or retrieve all the 4 corner?
    Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim swSelMgr                As SldWorks.SelectionMgr
    Dim swFace                  As SldWorks.face2
    Dim swSurf                  As SldWorks.surface
    Dim vPlane                  As Variant
    Dim i                       As Long
    Dim bRet                    As Boolean
    Set swModel = swApp.ActiveDoc
    Set swFace = swSelMgr.GetSelectedObject5(1)
    Set swSurf = swFace.GetSurface
    If swSurf.IsPlane Then
        vPlane = swSurf.PlaneParams
        Debug.Print "File = " & swModel.GetPathName
        Debug.Print "  normal         = (" & vPlane(0) & ", " & vPlane(1) & ", " & vPlane(2) & ")"
        Debug.Print "  root           = (" & vPlane(3) * 1000# & ", " & vPlane(4) * 1000# & ", " & vPlane(5) * 1000# & ") mm"
