Just started to use 2009. I have opened an assembly drawing
and the BOM is having issues. Specifically I use the split
balloons. The top with the item number shows correctly, but the
lower with the QTY is showing "BOM Error?" . Anyone having the same
issue? Or any ideas how to fix. I even deleted the BOM Which then
showed the correct QTY, created the BOM in the assembly itself and
imported that. After the import it showed the error again.
We just went 2009 and are now having the same problem with our split balloons that have the quantity. Did you ever get an answer or fix?
Dave
