2 Replies Latest reply on Nov 8, 2018 3:29 AM by Mario Zahren
    Stop program until error code has been eliminated
    Mario Zahren
      Hello all,
      I have a problem with the ".LockFile" Method because the file is open in SolidWorks. The error code is 0x8004020B.
      In my code, I want to display a messagebox that does not disappear until the drawing has been closed by the user. How can I do this?
      Here is my code:
                  string newComment = serialNbrValueValue + " | " + CommentVal;
                  IEdmEnumeratorVariable5 varEnum3 = default(IEdmEnumeratorVariable5);
                  DialogResult dialogResult = MessageBox.Show("Die Datei " + File.Name + " ist geöffnet und muss unbedingt geschlossen werden!", "Datei " + File.Name + " schließen", MessageBoxButtons.OK, MessageBoxIcon.Warning, MessageBoxDefaultButton.Button1);
                  if (dialogResult == DialogResult.OK)
                      try
                          File.LockFile(ppoRetParentFolder.ID, 0, (int)EdmLockFlag.EdmLock_Simple);
                      catch (COMException exp)
                          string errorName, errorDesc;
                          vault.GetErrorString(exp.ErrorCode, out errorName, out errorDesc);
                          vault.MsgBox(0, errorDesc, EdmMBoxType.EdmMbt_OKOnly, errorName);
      Any help would be appreciated.
      Thanks, Mario
        • Re: Stop program until error code has been eliminated
          Mario Zahren
          Probably not the most beautiful solution but this is how it works:
                      do
                          string errorName = "";
                          string errorDesc = "";
                          try
                          if (errorName == "")
                              break;
                          else
                      } while (true);
          For a more beautiful solution I would be grateful ...
