- Skoba 2.SLDPRT.zip398.0 KB
No one else had this question
Teodora,,, I probably could have done this in sheet metal using a swept flange but that is not available in 2011 so I used "surface flatten". First I made a "mid-surface" surface in order to put the new surface midway thru your part. This would give me a k-factor of .5 if it was sheet metal. Could change that but I don't know what your material is and figured it would be close enough. I have attached a step file for you.
The file you posted was done in SolidWorks 2011. I can only do a swept flange (with cuts) in 2016 & 2017. You would not be able to open them with 2011. Do you have 16 or 17 available to you?
Here is a 2016 file using the swept flange feature. I also used a k-factor of .5 and the flat pattern is equal to what I had posted with the surface-flatten feature. I only did one side of this but you will get the idea and use the same method for the other side or build it from scratch. I built this on top of your original file and you can hide or unhide your body. I you use the sheet metal "Flatten" on this it flattens and automatically hide the original body.
I was afraid this would happen with the "Swept Flange".. If you have "Surface-Flatten" available to you the results would be correct as in my first post (step file). If you do have 2016 or 2017 premium you can do that. Just look at the help file.
Notice what happens with the swept flange.
The flat pattern using the swept flange is not reliable in this case.
