I am trying to create an application for the guys on our production floor. I would like this application to open a drawing file, add some kind of text/note/stamp, and then print the file. I am having some trouble getting the text onto the document.
First, I tried to add a tooltip to the drawing. The tooltip shows up when you open the drawing, but it will not print with the drawing. So now I'm trying to add a stamp with the AddStamp() method in the EModelMarkupControl interface. I wrote something to convert the text string to a bitmap image to use as the stamp, but the AddStamp() method is not adding anything to the drawing.
Is there some clear way to do this that I'm not seeing?
After some extra sleuthing, I got it working. I was missing a reference with the CoCreateInstance() method.
EModelMarkupControl emmc = new EModelMarkupControl();
emmc = ctrl.eDrawingControlWrapper.CoCreateInstance("EModelViewMarkup.EModelMarkupControl.16");
MarkupControl.AddStamp(@"C:\test\stamp.jpg", (float)0.1, (float)0.1, (float)0.1, (float)0.005);
The floats are there because it's scaling weird, so I'll have to fix that next.
