I'm designing wire cable assemblies that have different end components. I was wondering if there was a way to have driveworksxpress auto assemble these cables based on a part number. Basically there are 10 different end components, and each is designated a letter in the part number. Is the add-in capable of selecting the correct component based on a user input (the part number) and then assembling the components to the cable?
Create a master file having all components (each mates individually with any relation to each other). And then using the drop down or other options you should be able to get the ones required in assembly and delete others.
