4 Replies Latest reply on Dec 20, 2016 12:32 PM by William Cruz
    SketchPoint Coordinates to Model Coodinates
    William Cruz
      Can anyone tell me what I'm doing wrong? It returns only the X coordinate, Y and Z return zero "0".
             internal void TransformPoints(SketchPoint sp)
                  try
                      MathUtility swMathUtil = (MathUtility)_swApp.GetMathUtility();
                      double[] cPT = { sp.X, sp.Y, sp.Z };
                      double[] vPoint = null;
                      MathPoint swMathPt2 = default(MathPoint);
                      swMathPt2 = (MathPoint)swMathUtil.CreatePoint(cPT);
                      swMathPt2 = (MathPoint)swMathPt2.MultiplyTransform(sp.GetSketch().ModelToSketchTransform.Inverse());
                      vPoint = (double[])swMathPt2.ArrayData;
                  catch (Exception ex)
        • Re: SketchPoint Coordinates to Model Coodinates
          John Alexander
          Is SketchPoint coming from a drawing? I had a similar problem a year ago which was resolved in this post.
          Troubleshooting mathTransforms, ivertex getpoints, and Views/Sketches.
          If that doesn't answer your question, it would be helpful for troubleshooting to know what sp.x, sp.y, sp.z evaluate to before the transform and what the transform matrix looks like.
            William Cruz
            For those who might-of had the same question, the code below works perfectly.
                   internal double[] TransformPt(MathUtility swMu, Component2 swComp, double[] dbSketchPt)
                        try
                            double[] xPt = dbSketchPt;
                            MathTransform swMt = swComp.Transform2;
                            MathPoint swMp = (MathPoint)swMu.CreatePoint(dbSketchPt);
                            MathPoint swMp2 = (MathPoint)swMp.MultiplyTransform(swMt);
                            xPt = ((double[])swMp2.ArrayData);
                            return xPt;
                            LogIt.LogError(ex);
                            return null;
              William Cruz
              An even simpler solution that does not involve any type of manual transform is by having SW do it for you using the SW Measure. The obvious bool checks are missing in the code below so if you are going to re-use, make sure you add them.
                     internal double[] TransformPt(SketchPoint sp)
                          try
                              bool retVal = false;
                              Measure swMeasure = default(Measure);
                              /*clear any previous selections*/
                              _swModDoc.ClearSelection2(true);
                              /*select the sketchpoint*/
                              retVal = sp.Select4(false, null);
                              /*get access to sw measure tool*/
                              swMeasure = _swModelDocExt.CreateMeasure();
                              /*run the mearsure on the selected sketchpoint*/
                              retVal = swMeasure.Calculate(null);
                              /*assign coordinates to an array of doubles*/
                              double[] cPT = { swMeasure.X, swMeasure.Y, swMeasure.Z };
                              /*clear selections*/
                              /*return points*/
                              return cPT;
                              LogIt.LogError(ex);
                              return null;
