PDMW Excel VBA Fails at CreateObject("PDMWorks.PDMWConnection")
Question asked by Sudheer Raju on Dec 8, 2016
Latest reply on Mar 11, 2017 by Tim Webb
Experts,
I am getting an error while running a MS Excel based Workgroup PDM VBA macro, which is to get the list of files stored in Workgroup PDM. This was working till last week, until we switched from SolidWorks 2015 to SolidWorks 2016.
The API at which is failing is while creating a connection object, Set connection = CreateObject("PDMWorks.PDMWConnection"). I get the below error message.
When printing the Err.Number and Err.Description, it results in 429 & "ActiveX component can't create object".
I think I have the correct libraries imported, as below.
I have Googled enough to find a concrete solution for this, but couldn't fix this. Tried the below.
1. Registered pdmworks.dll using regsvr32.EXE "C:\Program Files\Common Files\SOLIDWORKS Shared\pdmworks.dll" command
2. Installed Document Manager API (SOLIDWORKS Document Manager API.msi)
3. I tried installing latest .NET framework
4. Visual Studio Tools for Applications 2015 and Visual Studio 2010 Tools for Office Runtime
5. I have the registry key HKEY_CLASSES_ROOT\CLSID\{A2529E35-C5ED-4FDA-B2CE-3AD8CC86850E} correctly, ProdID shows PDMWORKS.PDMWConnection.1 and the VersionIndependentProgID show PDMWORKS.PDMWConnection, as I see that is what CreateObject looks for
Below is my entire code.
    Dim n As Integer
    Dim first As Integer
    Dim second As Integer
    Dim myFile1 As String
    Dim myFile2 As String
    Dim k As Integer
    Dim i
    Dim fileCount
    Dim serverName As String
    Dim userName As String
    Dim password As String
    Dim projectName As String
    Dim connection As PDMWConnection
    Dim alldocs As PDMWDocuments
    Dim doc As PDMWDocument
    Dim project
    Dim item
    Dim options As PDMWorks.PDMWSearchOptions
    Dim criteria As PDMWorks.PDMWSearchCriteria
    Dim results As PDMWorks.PDMWSearchResults
    Dim result As PDMWorks.PDMWSearchResult
    connection.Login "userName", "password", "serverName"
    Debug.Print "1. connected to PDMW..."
    options.IgnoreCase = True
    options.SearchCriteria.AddCriteria pdmwOr, pdmwDocumentName, "All", pdmwContains, "sldprt"
    options.SearchCriteria.AddCriteria pdmwOr, pdmwDocumentName, "All", pdmwContains, "slddrw"
    options.SearchCriteria.AddCriteria pdmwOr, pdmwDocumentName, "All", pdmwContains, "sldasm"
    Set results = connection.Search(options)
    fileCount = results.Count
    Debug.Print "2. Search result count..." & fileCount
    connection.Logout
    MsgBox "Macro complete..."
Your help is highly appreciated.
Sudheer
