This is probably a simple question for those experienced with SolidWorks sheet metal. I have a very simple sheet metal part that has a single down 90 bend. I would like to edit that bend but the bend angle is greyed out in the base bend feature and I don't find it called out anywhere else. Can someone tell me how to change the down 90 to say a down 85?
Steve
Like Deepak Gupta mentions edit your sketch,
What you need to do is delete the vertical (or perpendicular) relation and grab an end point and move the line out of vertical then dimension the line, if you don't move the line after deleting the vertical relation, SW still assumes vertical....
