hello, the issue is view scale following sheet scale, when I change sheet scale, view scale change also, but view position also change. I want only change scale, but view position should be fixed, or they only scale basing on view center. I want suggestion from solidworks, thanks first!
Select the view, right click and select "Lock View Position" and then change your scale...
