Does anyone know if or how I can remove the black line between surfaces? The top part of this side view example below is a surface loft and the bottom is a normal extrude boss base. I want to remove the black line as I need to make a design on the front face. Thanks in advance
Not fully understood your need but have you tried adding a fillet on that edge?
